parthenon voice switch middle position increases volume substantially
fritz
hi there
i encountered the following problem. parthenon's voice switch middle position increases the volume substantially. compared to the review panthenon videos on youtube the volume increase shouldn't be that big.
any idea?
thanks in advance..
by the way, apart the aforementioned it's a great sounding pedal.
I’m not familiar with that particular pedal, but just took a look at the schematic. In the middle position, you’re lifting diodes both in the op amp feedback path and the diodes hard clipping to ground. I’d be surprised if there wasn’t a huge jump in volume. Keep in mind that there’s a lot of audio compression on YouTube and levels might also be adjusted.
One remedy I can think would be to replace the diodes with LEDs. That's how the GuitarPCB Blues Buster pedal I have is run. There's still a slight volume increase, but it works well enough. And, it's not like you'll be flipping the toggle constantly
The Parthenon voice switch behaves slightly different compared to the Pantheon.
The toggle switch in the Pantheon switches between Hard clipping, Soft clipping, or Both.
The toggle switch in the Parthenon switches between Hard clipping, Soft clipping, or No clipping.
If you want the Voice switch to behave like the Pantheon you would need to use a Type-1 DPDT On/On/On toggle switch.
meanwhile i replaced the voice switch with a type-1 DPDT On/On/On. that was hard work o_O
however there is still an substantial increase in volume, especially with higher gain settings. i guess that's because compression kicks in stronger with certain settings.
i have the impression that the pedal started to sound different. it sounds like there is much more dry signal in the sound, especially when in soft (?) clipping / combo clipping mode.
maybe it's my ears, maybe i damaged something when removing the old voice switch?! probably i'll have to rebuild one...
thank's anyway
bump..
@Robert - Is this line between A2 and A3 of the Voice switch a remnant of the earlier version of the schematic or an actual connection?
Thanks!
The thin line represents the connection made when the switch is in the center position. It should probably be dotted instead....
BTW this PCB initially used a Type 1 but was updated a couple years ago for Type 2.
