MichaelW
- Build Rating
- 5.00 star(s)
A couple months ago @fig smacked me upside the head with a gauntlet and said "I dare you to build this pedal...." (or something along those lines as I recall.....
Of course challenge accepted!
Not sure why I was intimidated by this, it's actually a very straightforward build. As usual, @Robert laid it all out very nicely and the most challenging part of the build is making sure you have the right size components. After building both the Tourbus and the Byzantium I was in pretty good shape with low profile caps so I already had everything I needed.....or so I thought. Ended up missing the C100k Dual Gang pot, which delayed finishing the build a few days.
But the blue and white truck of happiness dropped off a package from StompBoxParts today so I got it all buttoned up.
The build went pretty smooth and the only thing I really had an issue with was not setting the bazillion 2N5088's down deep enough on the top board. So I had to bend them a bit for the back lid to fit on.
I started out setting the Gain and Bias trimmers at noon but noticed the bulb intensity was pretty dim. So I have the gain pretty much cranked and the bias backed off from noon quite a bit, maybe around 9 o'clock, I get the most lush effect with these settings.
The vibrato setting has some cool sounds but the chorus setting is where it's at for me. Really nails some of the early Trower sounds and Dark Side of the Moon sounds.
Compared to the EQD Depths pedal I built a while ago, this sounds more like a traditional Univibe and has more of a "swirl" as opposed to the "throb" of the Depths pedal. The Depth's pedal also has a lot faster speeds so it was kinda cool running the EVMini into the Depth set fast for a neat Leslie effect.
There's also not a lot of output with this pedal. I'm not sure if anyone else has had this issue. I have the level full CW to barely get to unity. I'm going to have to go back and read some of @Big Monk 's mod threads. I decided to build it stock because I didn't know what I didn't know, you know?
Anyway, fun build, great sounding pedal, highly recommended build!
