TAYDA Wrong Size UV Printing
PCB
I think is the side A because job is not in progress and I can edit it yet
It might be the line on the edge or might be the line not passing through the hole drilling of the LED
I wrote them because no idea why wrong size, what is the meaning because general sizes I think are matching
Some ideas on your side???
Screenshot 2026-02-18 102252.png Screenshot 2026-02-18 101835.png Screenshot 2026-02-18 101849.png ARTBOARD SIZES.png
I also think that the blank space above the design is a clue. Make sure you don't have an element that is outside of your artwork boundary somewhere - like something on another layer, etc. Or even if some of the pixels of the text on top are clipping the page boundary, it might push the blank area above. I had this happen in Affinity when I accidentally included some of the template in the export, despite the design being XX x YY, the preview showed white blocks outside of the boundaries of the main artwork.
It is a 1590A enclosure with a big button up this is why about the blanc part, this is a template for messurementand I have even split files to not mess anything aldo I didi a select all command and zoom out max but nothing looks out of the bounds, let´s see if they get back to me wit some explanation 🙌 thanks for your comments
Screenshot 2026-02-18 165539.png Screenshot 2026-02-18 165655.png Screenshot 2026-02-18 165250.png
Same thing... anything outside the artboard, messures ok, not sure, and coming from the Box Jobs the A is the only one not in progress and not in queue but again not sure...
  • Like
Reactions: Nic
