I need to build a compressor or limiter that I can use to regulate the signal in my effect chain before routing the signal to low headroom effects. The range to squeeze is not wide, would be fairly easy to set it only for a few outstanding peaks. I have a studio compressor like pedal, but it does not respect the threshold, and it has no dedicated attack release knob only a summarized know.
Do you know any schematic that I could use and is not very difficult to build? Even ones with fixed values for the parameters could be fine. The range to limit is very similar on the pedals where I needed the compressor or limiter. Maybe the only thing to leave adjustable would be the attack and release, but mainly the release. That would be the most crucial to be able to adjust it to the tempo of what I play. The attack, well useful if adjustable, most most of the time I need prompt, fast attack, so the essence is to set it to avoid outstanding transients, and that's it, maybe I will never touch it afterwards.
If the schematic is for stripboard, that would be the best, but no problem if normal schematic for normal PCB.
