Looking for simple compressor or limiter schematic
geso
I need to build a compressor or limiter that I can use to regulate the signal in my effect chain before routing the signal to low headroom effects. The range to squeeze is not wide, would be fairly easy to set it only for a few outstanding peaks. I have a studio compressor like pedal, but it does not respect the threshold, and it has no dedicated attack release knob only a summarized know.
Do you know any schematic that I could use and is not very difficult to build? Even ones with fixed values for the parameters could be fine. The range to limit is very similar on the pedals where I needed the compressor or limiter. Maybe the only thing to leave adjustable would be the attack and release, but mainly the release. That would be the most crucial to be able to adjust it to the tempo of what I play. The attack, well useful if adjustable, most most of the time I need prompt, fast attack, so the essence is to set it to avoid outstanding transients, and that's it, maybe I will never touch it afterwards.
If the schematic is for stripboard, that would be the best, but no problem if normal schematic for normal PCB.
How sustained are these transients? If you need an attack time of essentially zero then you are probably better off using a soft clipper. What kind of FX are you needing to limit the input to? There's no such thing as a free lunch when it comes to signal processing so it helps to have as many details as possible.
For some reason, all problematic devices (either compressor or chorus) seems to have problem with the same range on my guitar. This makes me think that either the specs of the transistor or some other parts are similar in them. I mean in the ones that have this headroom problem. The swap to 12v PSU doesn't really solve it, either not enough and the other problem with adjusting the distance of peaks of the signal from the headroom limit is that it changes the sound and quality of the effect. What I noticed: the closer the peaks to the headroom limit, the better the effect is. But due to outstanding peaks on some frets it is not possible without distortion.
To check how much the gain of the guitar signal raises after the 20th fret on my guitar, you can check this screen shot, where you can see the gain difference when I am picking an interval on the open strings and at the 24th fret with the same force (the sample sound file of which the photo was taken is also attached):
The difference between L and H needs to be reduced.
How long the sustain is on individual transients: the compressor or limiter should be able to handle almost all notes on the fretboard between frets 20-24, more precisely from F4-E6, that is 349Hz to 1318Hz. And the tempo of adjacent notes is fast, mostly 1008 BPM (song tempo 126 BPM), so the release should be able to handle that.
I don't mind if it is a compressor, limiter or soft clipper, but the solution has be suitabe to be adpated to pedal form and should not distort the notes in a way that the listener can notice.
The particular device I am working on is the Behringer UC100 (schematic attached). I have adjusted the bias by adding a trimmer instead of the controller resistor (R3) in the schematic (the trimmer is in the schematic but in reality unsoldered on the board in the factory). With the recent headroom of the element that the bias is applied to (I guess some IC), you cannot achieve that the notes between frets 20-24 on my guitar would not be distorted and the noise floor to stay low at the same time. If you set the input into the pedal low to keep the signal under the headroom limit, after the pedal you need to raise the volume significantly, and the background noise will be audible and disturbing. If you set the input volume for the pedal to avoid the noise become audible later, the signal won't fit between the limits of the headroom. But this is because of those outstanding peaks between the frets 20-24 on my guitar. At the frets above that (0-20), the gain is low enough for the signal to stay under headroom limits. I have another guitar too with more even gain along the neck (Schecter Omen), but even in case of that the very last frets (23-24) distort.
Or, I can swap the transistor as well, because there is space on the board to be able to do mods comfortably. If you can suggest another transistor that offers more headroom at the other specs remaining the same (at the recent setting the chorus effect sounds just perfect, I don't want a swap that alters the sound character of the effect too much): Behringer-UC-100-Schematic.png
Madbean Holy Roller / Bajaman LA2A Optical Limiter
Demeter Compulator reputedly works well for limiting :: build on perf or get the PedalPCB CONSTRICTOR
PedalPCB Delegate (ie Warden), build up the Boneyard version.
AMZ Q&D2 is a super-COOL SSM2166-based comp/limiter. IIRC, PCB not offered by Orman anymore — rumour has it he's coming out with an updated version — but the schematic is still available, you could do your own layout.
Here's a cool little limiter:
by w2aew PCB on oshpark, there are a few variants so choose the best option for yourself
https://oshpark.com/profiles/LRY/page/2 and page 3
- W2AEW audioleveler w amp : newest version
- Audioleveler by W2AEW (C4, new value)
- Audio limiter/leveler by W2AEW : Original
BYOC's Multi-Band Parametric Compressor is another good'n, but you'll have to build it on per/vero or have a board fabbed —
RIP BYOC 🪦
Limiters listed in my HD:
  • mxr143schem-page-001
  • MXR 143 LIMITER schematic -page-001
  • Guitar Limiter Schematic - Data Schema • 135-02f9c2c122
  • DOD 525 Compressor Limiter Schematic
  • Compressor-de-Áudio-Simples-Mono
  • Buchla 292 Lowpass Gate or Dynamics Manager
  • Power Stage schematic powerst
  • LIMITER by COMPOSITION4 diysb forum mUFthfL
  • Fast Audio Peak Limiter By Phil Allison
  • DOD FX30 GATE-LOOP
  • circuito compresor de audio
  • Audio_Limiter_DJ4BG schematic SIMPLE!
Boss' LM2 schematic is floating around the Web.
The DYANARAWS is essentially a limiter marketed as a compressor. Reportedly sucks lows.
Hmm listed on my HD:
alesis micro limiter which isn’t micro at all​
audio_compressor_limiter_03 NL3ASD Amsterdam Radio blah blah​
CRAIG ANDERTON Compressor-Limiter by MAO (Vero project)​
DOD FX30 GATE LOOP?​
epfm08 Compressor Limiter Lazy Finger Layout​
FAST AUDIO PEAK LIMITER sacked dot co​
wholenote BLM-270 limiter (Boss LMB-3 Clone) [Guts Shots​
ETI Magazine Article with limiter — pg1,2,3,4​
You mentioned a preference for vero...
I'd go with the Compulator or the Bajaman LA2A, they're both compact circuits, simple controls...
You might prefer the Anderton Comp/Limiter with MAO's mods.
Demeter suffers from distortion problems as well. Maybe not intermodulation, but a crackling-like effect on the decay can be heard when I play at the 20-24th frets. Very likely due to a low headroom of some element. The trimpot setting it offers has no effect on it. It is the wide dynamic range of my guitar that causes it. Or maybe some bias setting is off-center.
The AMZ is OTA isn't it?
The rest I will read and will respond.
Do you have more than 1 instrument? Have you eliminated your guitar as a potential source issue? Only asking because I used to have a guitar that didn't play nice with high gain and compression from the neck being slightly twisted with the dreaded heel hump.
The root cause is definitely something in the guitar setup, what you describe shouldn't happen if the guitar is set up optimally., from a physics perspective those frets should actually produce less energy because they vibrate less.
However, tbh I wouldn't use an optical compressor for this task, the attack isn't that quick and I think you would still let a lot of transient through. It's not DIY, but for the cost of DIY you could check out this https://www.sonicake.com/products/source-comp
It's "based on an 1176", how close it really is to that circuit I'm not sure, however, if does have very quick attack and is very configurable for a great price. If it's the first thing in your chain it should even out things nicely. Importantly it has a gain reduction meter so you can see when it's compressing which should help you dial it in just right for your situation.
Something else to consider might be an active volume circuit, you can reduce the signal going into a compressor to maximise headroom, then utilise the makeup gain of the compressor to compensate / control the final maximum signal level.
To talk about the headroom issues for a second in various pedals, it's basically impossible to design those out of certain circuits. BBD based devices such as analogue chorus and delays, OTA based compressors, and a few other things are just limited by needing lower inputs. No amount of swapping transistors or op-amps can really fix that.
The only the compressor before the problematic pedals and even dynamics from the guitar is the solution.
I have a Schecter Omen guitar here now that I borrowed, it has even volume all along the neck, except for the 23-24th fret, there there is also a little jump that would benefit from cutting.
But your response is strange because I asked about the dynamics problem on my guitar elsewhere, and there commentors were pushing the opinion that guitars behave like my guitar, an the Schecter is a rare exception.
It shouldn't be so extreme though, that really indicates that there's an issue with the neck alignment, the frets, or both. Also have you tried adjusting the heights of your pickups? Sometimes if they sit in a particular position they can be accidentally located in a sort of node.
Schecter do make excellent instruments in general but sometimes you can get the rare high fret on any guitar. If you can find a third guitar regardless of brand somewhere you can for sure know it is your personal guitar. Unfortunately you may have to take it to a professional to get an inspection and setup, I did that for a bass that I couldn't intonate no matter what I did. Have you already ran the Omen through your FX chain?
Yes, I did. There is difference. The even dynamics from the Schecter can help gaining headroom for the problematic effects. Does not solve the problem completely, because the very last frets 23-24 are still a bit outstanding, though much less than on my guitar. But the Schecter makes it possible to apply even compression all along the neck for example, and lower noise floor in low headroom effects (the signal can stay closer to the headroom limit, thus less raising of gain needed after the effect).
To completely get rid of the high noise floor problem in my low headroom effects, the limiter or compressor would still be needed, because if I can diminish the peaks on the 23-24th frets on the Schecter, the noise floor can return to the ideal level in that case. So all in all, very big difference with the Schecter, but due to the nature of the problematic effects the limiter would be useful.
I did adjust the pickups lower on my guitar earlier, but I did not like the response in that case. More difficult to play, the decay becomes much shorter, the sound becomes staccato-like. So I raised them to the level where they now have been for a long time. As I remember it did not make a big difference in dynamics, but I will try again. However due to the response problems mentioned it won't be a solution if this adjustment reduces the dynamics indeed.
At the moment the strings are much lower on the Schecter, and still the response is way much better than on my guitar with higher pickup settings at the moment. Less staccato than on mine at the same height.
In connection with the compressor/limiter. Examples have been mentioned above, but it is still unknown how any of those will behave in my chain. As it was mentioned OTA pedals are not the best choice because of headroom options for the specific purpose I need it, opticals are slow that I can also confirm, the FET type may work. But we still did not consider an option that would also be worth considering: I have a Carl Martin Compressor/Limiter that is a FET compressor, indented to mimic a studio type compressor, and it has absolutely no headroom problems. I did try it for the purpose I presented above, but unfortunately it is not suitable for cutting just the tip of the peaks at the moment. Oddly, the Threshold works unlike on normal studio compressors that I tried (plugin version in DAWs). On the computer, when you set the Threshold to a certain amplitude value, the signal doesn't trigger compression if the amplitudes are lower than the threshold. However in the Carl Martin, the compression is triggered even in that case, if you set the Ratio higher than about 30% of its rotation max. This way you cannot predict how the compressor will behave at the settings you choose as the obviously right setting. If this annoying feature could be removed from the circuit, the Carl Martin would be suitable for my purpose. The attack is fast enough on that one.
Your guitar needs a set up…or your technique changes when you are accessing upper frets and that is causing issues when scrutinizing a waveform. 🤷‍♂️
Okay, but what setup you mean?
As in, take it to a local luthier / tech, tell them the issue you are having, then they will adjust the neck, maybe redress the frets etc. Otherwise you might just be chasing your tail.
If you are still having issues after that, then it's time to select a compressor with a fast attack and hard knee, the "issues" you describe with the Carl Martin is probably because it has a soft knee, which means compression is gentler but earlier.
But I have already done this in the past. And even after that the guitar sounded like now.
No, the SSM2166 IC is VCA.
A note about luthiers, repair-people — they're not all cut from the same cloth. Par example...
A friend with a PRS had a bridge problem that caused tuning issues. He took it in to a local shop that "fixed" it.​
Tuning was better but fundamental problems with tuning still existed. He found a shop that specialised in PRS and the PRS-trained guy said something like:​
"oh, it's probably 'xyz-problem', most general techs aren't aware that normal approaches will gouge that screw-head — bring it in".​
Sure enough, the screw-head the string runs over had a nick in it from the previous repair attempt and the PRS-savvy tech fixed it — now the guitar is in regular rotation as one of my friend's main guitars.​
Not to take away too much from the first tech, as he is skilled and highly respected on the scene here — he just didn't know the ins/outs of the PRS bridge-system.
I understand that you refer to, the question is whether such nuances apply to my case as well. And if yes, what is it that causes the difference.
