Multimeter recommendations
Search your local pawn shops for a fluke with a frequency counting function(Hz) and make sure the leads don't cut out when you jiggle them at the meter.
And check the battery compartment.
I have seen dozen of flukes in pawn shops that look brand new.
There is a Fluke 12 on eBay for $90 shipped.... if you don't buy it I probably will.
My Fluke 10 is my favorite meter of all time, the 12 is an upgrade because of the capacitance function.
It doesn't have a frequency counter like @jwin615 recommended, so keep that in mind if it matters to you.
I’ve amassed a few meters over the years, the one I use most often these days for pedal stuff is this little pocket one:
Reads Capacitance and Hz, which you definitely may want once in a while. It looks a bit Iike a cheap toy, but mine’s been ticking along for several years now 🤞;)
I use a Fluke at work. Think it’s probably way overkill for pedal stuff, and I wouldn’t buy one with my own money, but if you find a cheap one in good shape…why not 🤷‍♀️
I’m picturing something with a potato…🤔
a2a12069-87c5-4878-958b-1f8ea81137a0-jpeg.25868
It was like $50 and outperforms my Flukes that cost more than 20x.
