18v AC for DEFX Atomic duck?
drgonzo1969
I am wrapping up populating the PCB for DEFX Atomic Duck but I keep on putting it off because I don't have a power supply to test it out and play it. It runs on 18v AC power rather than DC. Is there a way to add some sort of conversion to DC with vero. Or could I make one of the outputs on a PPCB 4-tap DC converter into 18v AC? Other ideas to power this thing other than special 18v AC power supply?
If you look at the schematic, the 18v AC is being regulated to a bipolar +/-15vDC supply.
This is also tge internal supply of a lot of the Aion effects that use DC-DC converters. Depending on the current draw, you could probably build this up on a daughter board and bypass the AC rectification and regulation components.
