I have a friend with a TS9 that failed after plugging in reverse polarity from a 12v adaptor - smoke, crackle, pop…. After visual inspection it appears that a diode busted, it actually seems to have popped in half.
After research I found this part of the TS9 power circuit:
I didn’t quite understand that as I was expected the diode to be in series, but later read that older circuit used W03C (1N4001) in a “crowbar" formation, where it goes between +9V and ground, with the cathode pointed toward +9V.
From what I understand reverse polarity will generate so much current that the diode bust, thus protecting the circuit.
So I have 2 questions:
Is my understanding right ?
And can this diode be replaced by a 1N4817 in the same “crowbar” configuration and work as a protection diode ?
