DM me your address.Yes exactly
FYI, can't fix this one. Robbed parts to make a fuzz for it's original owner.
I love SolidWorks because it's what I know, but I really don't recommend it to anyone unless someone else is paying for it for you. Everything I personally do in SolidWorks could be done just as well in Fusion360. Also my brother-in-law (a mechanical engineer) recently introduced me to Onshape, a free web-based CAD tool that he's started using since he changed jobs and no longer has access to SolidWorks. I haven't done much with it, but it seems to be every bit as capable as something like Fusion360, and it's free to sign up, plus you get cloud storage for your design files so you can work on them anywhere you have an internet connection.SolidWorks and Rhino are the old “professional” standards, and even if you are a quick study, can be slow to learn. (Plus SW is stupidly expensive.) Starting on a web based, free platform makes a lot of sense; while programs tend to use different approaches, you still begin to get a feel for how shapes get made.
Yup, all the early things I designed ended up eventually breaking because of all the sharp corners, I had to learn that one the hard way. This brings up another good point though, in FDM printing you're doing multiple flat layers on top of each other, so the direction of the layer lines in relation to expected stress on the part is something to keep in mind when you're slicing your part for printing. I've had parts that I printed at a weird angle because they ended up being stronger that way.@vigilante398, above, makes a very important point. (Actually, he made many!) But I’m interested in one of them, because I’m sick of seeing failed parts due to this—filets! Internal cutouts where straight lines meet—whether you’re printing, laser cutting, or machining, are inherently weak, and prone to having a crack develop (and rapidly travel) right at that corner. Put a radius there. Even .020 (0.5mm) radius is fine, and visually, it’s still a sharp looking corner.
