R Route14 Well-known member Jul 28, 2022 #1 Any difference with using a 5mm vs 3mm LED (of the same color) for clipping? I know color matters. Thanks!
Big Monk Well-known member Jul 28, 2022 #2 Route14 said: Any difference with using a 5mm vs 3mm LED (of the same color) for clipping? I know color matters. Thanks! Click to expand... Depends on the circuit whether they will fit but there is no difference between the sizes from a tonal standpoint.
spi Well-known member Jul 28, 2022 #3 Assuming the forward voltage is the same... and usually it is but doesn't hurt to check if you have a dmm.
R Route14 Well-known member Jul 28, 2022 #4 Big Monk said: Depends on the circuit whether they will fit but there is no difference between the sizes from a tonal standpoint. Click to expand... Awesome thanks! I didn't think so but thought I'd ask. I definitely have room on the board and a surplus of 5mms.
R Route14 Well-known member Jul 28, 2022 #5 spi said: Assuming the forward voltage is the same... and usually it is but doesn't hurt to check if you have a dmm. Click to expand... Yeah I'm not sure why I didn't think to start there. That's a good idea.
