andare
- Build Rating
- 3.00 star(s)
I have a bunch of octave fuzzes (Joe Gore's Screech + a Foxx Tone Machine and an Ampeg Scrambler clones I built from Musikding kits) and they are wonderful but I usually play with an always-on Fuzz Face and adding fuzz to fuzz makes my amp go splat.
Enter the Green Ringer, which is just the octave. I have a few riffs where it'd be useful to be able to use the octave as an accent so instead of dropping 200 Euros on an EQD Tentacle I decided to build this and add the relay switching with the temporary function.
The first time I built the board I got solder in virgin holes. After using those special hollow needles and purchasing an Engineer SS02 solder sucker, I ended up freeing the holes but the pads came off.
I ordered a second board and was extra careful with the iron. This is a tight one. I matched the resistors, caps and diodes in the octave circuit. Pretty happy with the sound. A dedicated octave fuzz sounds better but this is good for adding that flavor occasionally.
As you can see from the guts:
I made a big mess inside. The relay board is connected to the main board with pin headers, however the boards are floating inside the enclosure, held by wire tension. I had to cover the enclosure with electrical tape to avoid shorts.
The other issue was soldering two wires to the minuscule lugs on the Lumberg DC jack, one for the main PCB and one for the relay. Why is everything so tiny and cramped?!
The fact that I used a 1590B (thanks @MichaelW for the drill measurements! Of course I still botched it a bit) made things more difficult. The box is too shallow to mount the relay board on top of the switch. And the main board has no switches or pots. Double whammy.
This is a build for better builders than me
I used a green LED with a lens. I should've breadboarded the LED to find the right CLR. As it is it's a bit faint. Also this is my first build in a painted enclosure. It's a Hammond so quite expensive. Sorry no way to do graphics.
I rate the build 3 stars because it is a quality product, especially the relay board - the temporary function is really cool and reliable - but it requires better skills to be executed in an elegant fashion. And to think that I hail from Milan, one of the world's fashion capitals...no wonder I had to relocate to Poland.
I see other similar clones are integrated with the 3PDT board - that would allow the footswitch to support the board inside.
