Jdilly
Hi All. I'm building my second Abyss pedal build and am running into some issues, which I can't seem to resolve.
Here's where I'm at:
- I'm getting signal in bypass, but no sound when switch is engaged
- Front LED light works when pedal is engaged
- I swapped the switch and rewired that, thinking that was the issue, but it didn't help
- I had plugged in a 12V power adapter at one point by mistake when testing
- I'm new to voltage testing and reading schematics, but started tracing from the + and noticed the diode (D1) wasn't getting and voltage. I swapped that diode out and now I'm getting 9.28v from both sides, but no power beyond that (C9, IC1, IC2, etc)
- I swapped out the ICs (in case they got toasted), but still no power reading from any IC points
- Lastly, someone suggested cleaning the PCB with isopropyl alcohol, which left some residue around the connectors
Is it possible that I bricked the PCB by plugging in that 12V power? Any thoughts on what else to do?
Here's the link to the schematic: https://docs.pedalpcb.com/project/Abyss.pdf
Thanks!
Thanks!
