Acetylene Overdrive - Wampler Ace 30 Something
Rpschultz13
Recently built this. I used the original Tayda drill template but it was tight at the bottom and didn't allow for the use of Illuminated LED switches. So I modified the template as listed in the Templates area. Now it allows for Illuminated LED's. I *love* the breakout boards for those. I used resistor cutoffs to connect the switch breakout boards to the main board. Works great, very clean.
(of note, the LED's in this photo are backwards. @brightlight pointed this out and helped me fix it!)
Very clean. Looks great. Next tayda order, grab some male to male 2.54 header pins. Makes the pad above pad footswitch install a breeze and looks damn tidy as well. Just make sure everything is tightened down before soldering.
So, how's it sound?
I forgot about this, been working on other stuff. Playing it tonight for a while, mostly nice. It seems to have some low end problems. Not sure if I did something wrong or what, but it tends to fart out the low notes if I push them.
Ideas?
