Getting 4.74v on Q4 and 5.06v for Q2. Thanks for the info.Just curious, I've had a few BS170s with drain voltage readings way out of expectations in the past.
My vero layout build of the Acetylene is working, but I'm getting a ton of hiss. Very similar issue I had with my Azabache builds, which I was never able to resolve.
And false alarm, must have been an impedance mismatch causing the noise/hiss as it sounds correct feeding the input on the amp. (Was originally testing it plugged directly into the power amp, found that adding a buffer between the two solved the noise as well with this setup)
