I modded my real HM-2. The schematic at the Peperspedals link shows it wired right in between the flip flop switching (Q4 & Q10). The Promethium also has the in and out buffers, so it should work the same.
You can see where "send", "return" and "output" are wired, when using the Tagboard layout he recommends.
http://tagboardeffects.blogspot.com/2012/01/mini-blend-jfet.html
Attached is a schematic of the blending circuit, though Peppers used different values.
On the Promethium:
"send" between Q1 and C2 to the blend board, which then goes to blend pot #1
"return" from volume #2 to blend pot #3 (notice " disconnect here")
"output" from blend pot #2. I'm not sure if YOU need that 1uf (C32 on the Boss schem) as you're using true bypass.
On the Promethium:
