mdc
If you're using a power supply brick, all you'd need to do is sacrifice one of the barrel cables—splice the power side and solder on a pair of aligator clips. Clamp those to whatever pots you have lying about until you find a value that works for a given circuit. The sag control in the Fairfield Barbershop is just a 10K variable resistor/pot in series with the 9V supply.
