debrad
Quick follow up...built this to adjust the input voltage on my Marigold build (and any other 9V centre negative pedal I want to play with) based on a couple of suggestions on Beavis Audio (and Zachary Vex's suggestion to use a 5k potentiometer).
Hooked it up to my Marigold and was able to drop the input virtually all the way down to it's lowest setting and the only thing that changed was the overall volume and the brightness of the LED.
