Adding clean blend to Boneyard Delegate
effilctar
I'm needing a bit of help with a clean blend. I've tried a buff and blend after the delegate but the level knob before the blend caused the ratios on the blend to be super inconsistent. I'm trying the "Additive" Op Amp Blend from this Thread . I have removed the tone control and put the blend in how I think it should work, but it is for sure not working right. It sounds more like a tone control which I feel is odd. The bits I added are around the "in send return out" pads but I assume that is obvious to the experts around here. Thank you in advance for any help. Delegate Compressor Blend.png
