Adding infinite delay momentary switch to Seabed
allsmoke
If I want to add a momentary switch to give infinite delay on seabed pcb. I've seen to add one leg to leg 3 of feedback and the other to leg 3 of delay. Is it that simple?
Yeah, you can add a trim pot (or resistor) inbetween to give you more control of the oscillation
Sorry read that with when i wasnt wearing glasses. Ive seen it this way (as pictured in my previous post), where you short legs 2/3 of the feedback pot. This way has worked on both the seabed and the magnetron. Also tried it on the pt80 from GGG it also worked but wouldnt work if there was a resistor/trimmer being used.
Where you able to do this? I'm thinking of doing the same.
Highly recommend the pot to control the shorted feedback; that way you can let it ride out longer without becoming too loud etc...
