J jojofogarty01 Member May 13, 2020 #1 For the ADHD I noticed you can switch between true bypass and buffered. Should I use a normal 3pdt breakout board or should I use the one for buffered effects?
J jojofogarty01 Member May 13, 2020 #3 Barry said: I think your going to want to hard wire that one Click to expand... How can you tell? is there a general rule for when I can use a breakout board versus when I should hand wire it? Thanks
Barry Well-known member May 13, 2020 #4 jojofogarty said: How can you tell? is there a general rule for when I can use a breakout board versus when I should hand wire it? Thanks Click to expand... On that one the number of connections don't match up for one, also if the build documents show it hardwired anyway other than traditional
moonlightpedalbuilds Well-known member May 14, 2020 #5 Would this work? It should, right? 3PDT Breakout Board (for Buffered effects) - PedalPCB.com 3PDT Breakout Board for Buffered Effects www.pedalpcb.com
Robert Reverse Engineer May 14, 2020 #6 pedjok said: Would this work? It should, right? 3PDT Breakout Board (for Buffered effects) - PedalPCB.com 3PDT Breakout Board for Buffered Effects www.pedalpcb.com Click to expand... Not for this one... The wiring for the ADHD is a little different from any of the other projects so it will need to be hard wired.
