Amentum Boost
ap123
I built this amentum boost and can’t get any sound on, or off even with true bypass. The led works when turned on and off. I can’t figure out what I did wrong, can anyone suggest any changes?
I also cannot upload a photo, it says "it is too large for the server to process"
When I have that problem I find that cropping the photo usually gets me in under the size limit. I also seem to have less trouble when uploading pictures using the media button in the toolbar above where you type rather than the "Attach files" paperclip below, but that could be a false impression.
Check your in and out jacks are wired correctly
Tips to your 3PDT, sleeves to the pcb top ground pads, it's most likely to be a fault with the jacks or 3PDT with no signal in effects or bypass
You can also get free image resizers to make your images smaller
