I did not want to hear the diff between LM308 and OP07, but unfortunately I did and now I'm stuck. The good news is I have a small stash of LM108AH metal cans. I've had them so long I don't recall where, when or why I acquired them. They sound the same as LM308 DIP, unless you look at them and then they sound better. Check the date code, they're older than a lot of you guys. Believe it or not, that's the AMD logo. One of the premier advanced microprocessor manufacturers used to make military-grade opamps!
If you like to turn your Rat up to 11, then an OP07 will sound about the same. I hear the difference at low gain, on the cusp where the opamp stops clipping and the diodes take over. YMMV.
BTW, the Voodoo-1 uses an LM308, but an MC3476 sounds nearly identical in that circuit.
