Not sure where to get in large quantities, but here are 2 sources (never bought from either, but they’ve been around long time and I’ve never heard bad about them)Anyone have any idea where I can find ground contacts for 1/4" PCB mounted jacks?
				 tubedepot.com
					tubedepot.com
				How could anyone forget Cliff!?That's them, perfect! Thank you!
I checked Neutrik and Switchcraft but totally forgot about Cliff.
For future reference:
Cliff Part # FCR14422
				 tenor.com
					tenor.com
Cliff Burton Shredding GIF - Cliff Burton Shredding Cliff Em All - Discover & Share GIFs
Click to view the GIFtenor.com
Oh. Different Cliff!
Here is how Buffalo Fx done it in my pedals, the old pop rivet in the enclosure trick :Anyone have any idea where I can find ground contacts for 1/4" PCB mounted jacks?
The only issue I see with that is technically you don't want to make enclosure ground at more than one location.
It's grounded on both jacks just like PedalPCB Jacks are???The only issue I see with that is technically you don't want to make enclosure ground at more than one location.
That seems one step below the behringer spring against the bottom plate. It just doesn't inspire a whole lot of confidence for me personally.I’ve seen a few production pedals that used a bent metal piece that keeps contact with the lid when closed up.
That's fair. I guess as long as the pressure is minimal then it's a step above the ground spring. Anything that pushes or pressures boards inside the enclosure seems like it would be undesirable in the long run though. But I have never seen a production pedal fail due to either of these options so I admit I am unjustified in my bias.I'll say that what @KR Sound describes is a good method as opposed to ground springs. I used ground springs for early revisions of the Pompeii and what I did not like was how much pressure was put on the solder joints.
My Mooer E-Lady had a PCB mount tab that connected at the screw for the backplate and that was a really low friction, high contact connection, assuming the screw did not come loose!
