Arkaim Fuzz footswitch wiring?
Sorry I already posted this question on the forum but we lost all our posts so I'll ask again..
Could you please tell me how to wire the 2nd footswitch again?
hi , thanks for posting this, how are the bottom right holes wired? Is it in/ground/switch/out the way you normally do?
Also the the 2pdt switch a on/on or a on/off/on?
Thanks
Ray
The right FS is wired as usual, not sure about the switch.. I'll look at mine when I get home and get back to you.
Edit: sorry, didn't realise you had a reply already :) disregard
N
So based on the comments above, would this be the correct wiring for the Arkaim?
not quite, with your footswitch on the right.. the middle lugs on the left and right go directly to your input/output's positive tabs and those points at the top of the PCB are your ground/negative for the in/out jacks. Hope I explained that ok.
Edit: just realised that's probably what you meant in the first place but just making sure :)
N
Great, thanks! Yeah, that is what I meant. Probably should have just drawn the jacks in too to avoid confusion. Thanks for confirming though!
