Attenuator for Fender Blues deluxe (with effects loop)
neiltheseal
Hey everyone. My amp is way too loud and the family are complaining.
I'm looking for an option to reduce the volume in my Fender Blues Deluxe Reissue. I know it has an effects loop. JHS has the little black box that claims I can chuck it here in the effects loop and I can reduce the volume but keep my tube amp goodness.
Does anyone have any experience with reducing volume in a tube amp?
  1. Will something like a balck box work or do I need a real attenuator?
  2. Does anyone have a schematic for the black box?
  3. Is the black box just a volume pot?
  4. Will I destroy my amp if I put a volume pot in the effects loop?
  5. Is there anything else I need to know?
20 years ago i bought a used US made Blues Deluxe. Ever since i use it with a DIY volume box, i also tried the Tom Scholz Power soak with it
1. The Volume Box does the trick
2. https://fmi93superamp.wordpress.com/section-04-fx-loop/ or https://stinkfoot.se/archives/2159
3. yes. You could add a DC blocking cap which could also dime the bass a bit.
4. No, it just dimes the post preamp section. But a Power Soak could set down the lifespan of the power tubes if used extremely.
5. No
I believe there is a That Pedal Show episode about this very topic. I think they did use a volume box.
I recently built one following this diagram.
I did the same thing with my blues deluxe and it worked great for reducing that massive volume increase you get between 2 and 3 on the dial. It does NOT give you power tube distortion, it's just a clean volume tamer.
I built a fancy one with a footswitch and an LED. This is the wiring diagram. I think I used an A100K
Thanks for this.
Does this act need power? Is this only for the led or am I missing something? I had assumed no power wound be needed here.
Hello neighbour my old friend
You've come to my front-door again
Because of amp-volume softly creeping
Up towards breakup for good-tone reaping
And the valves did glow from all the gain
thus your complain
requesting the sound of silence
Endless knob-tweaking to find the zone
Of narrow sweet-spots of power-tube tone
'Neath the halo of the jewel-like lamp
I tuned the PRESENCE of my old tube-amp
When my ears were stabbed by the flick of switch called "BRIGHT"
That split the night
And torched the sound of silence
And in the naked chassis I saw
Ten thousand volts, maybe more
Power without proper ground-wiring
All exposed for widow-making
I looked for a schematic never shared
No one dared
Disturb the mains, that make the sound of silence
"Fools" said I, "You do not know,
Silence me forever if this thing blows
Here, use modern wiring that I might teach you
Take new amps and view I beseech you
But my wiring diagrams, like signal straight-to-ground, fell
And echoed through the walls in silence
And the neighbour vowed and made
A call to the cops for a raid
And the tubes flashed out their warning
In the cab's feedback that was forming
And the constable said, "Your court-date appearance
Is written on the ticket's back
BTW, nice stack.
Leaving in his wake, the sounds of silence
Thanks for the replies everyone. I'll put one of these together once my amp is fixed. My family will be so happy.
Tayda accidentally sent me a 1590A enclosure and I havent figured out what to do with it. This might just be the project for it.
Sounds like a plan. In fact this my first pedal…and look how that developed over the years.
I started one of these a while back. I thought instead of using up two jacks and two patch cables, I’d just cut one patch cable in half.
I don’t have an amp with an effects loop. I was gonna give it to a friend with a deluxe. I was trying to figure out whether I did it right by measuring resistance and decided something was wrong and pulled it apart.
I still like the patch cable idea though.
Or 1590A one of the following ... 😎
https://www.pedalpcb.com/product/rangefinder/ ... well, maybe.
https://www.pedalpcb.com/product/twosticksofderm/ 🤘
THIS
goes together with
THIS
https://www.pedalpcb.com/product/6-10-6/
https://www.pedalpcb.com/product/pcb156/
https://www.pedalpcb.com/product/pcb654/ oh, wait, it should but... nope to this last one
That one is going to be used for a beginner-friendly kit offered by a particular vendor so the components are spread out a bit and the pads are slightly larger than normal.
There's another 1590A based project on the way but you're probably going to want to have it milled by Tayda rather than drill it yourself.
I would just use an actual attenuator between the output and speaker. I do this for my champ to get that over driven tube sound. I pretty much use my jazz chorus for everything else n
