Audio vs linear.
Radkins80
What would the difference in sweep be if I used a 5k linear instead of audio taper on a Triangulum boost? The right angle pcb terminal is all but impossible to find in audio taper. StewMac sells the linear taper all day long.
You could use B taper, it’ll just have a different sweep (Example, unity volume will be at a lower setting with B taper)
Stompboxparts has them right here in the US
Taper Tricks
