Baritone or conversion neck?
If I ever decide to get one it would be something like this. This is the coolest one I've seen.
If someone has a semi hollow baritone multiscale I’d be into it. I don’t see myself doing much weedly weedly on this one 😂
Ooh. Maybe I make one.
Shoot. If I'm gonna be all into doing fretwork. I've been jonesin to do a thinline jazzmaster.
Mmm. Gotta find something appropriate to put my bare knuckle pig-90s into. Currently in an ash/maple carvin bolt. Too bright for that guitar.
I've probably posted my baritone here before - it's one of my favourite instruments. It's a warmoth partscaster, so 28 5/8" scale. Setting it up so that it's comfortable and sounds alright was a bit of a learning process. I settled on 62-13 strings tuned to Drop-G. Beefier strings brought mud. Higher tuning put a ton of tension on the strings and broke high e's so I gave it up. I mostly use it to play gloomy leads but, with some distortion, it provides a kind of inarticulate growl that can really fill out some space. The bridge humbucker is extremely hot (17k or something), the neck is a PAF. I've got the coils in both positions split and usually play that way.
This is what it sounds like (Blue side of a Pro-10, various delays, Empress trem, into a Sunn Beta, with a bunch of eq shit following that I need to tweak because it's creating some artefacts).
It's not the most versatile guitar I've got. I probably could have made better choices with pickups but it does what I want it to. Long way of saying everyone should have a baritone. 10/10
Drop G like a major 6th below standard tuning? That is loooooow. The Rivolta I got is in B.
I use an alternate tuning on my Bari where the lowest string is that G. I used to use that tuning on a standard guitar, which was tricky to intonate.
