Nostradoomus
MIGHT AS WELL JUMP @Feral Feline
Wait, you’re telling me I DON’T have to hoard PCBs?That way you can find a circuit you like, audition it, without resorting to buying hoards of PCBs.
No, I was being facetious — OF COURSE you need to HOARD BOARDS... boarder-hoarder, it's in my sig, "Boarder Solidarity".Wait, you’re telling me I DON’T have to hoard PCBs?
Not sure if I should start a new thread for this. I have a Donner Comp/limiter that I love the sound of for some reason. It has a loose power jack after seven years, so I thought I'd order the newer Ultimate Comp but it doesn't sound the same, not nearly as good to me. Is repairing the old model possible? I don't want to mess it up, I have it turned on all the time while I'm playing. Is it just a rip off of some other pedal?
Which book is it?I completed the Boost pedal kit. It was a lot of fun. It was a bit pricey to get to Canada but it sounds good. Next is a Jfet preamp from Tayda so I can learn to drill enclosures. Also ordered a kit from Aion FX. Thanks to everyone for the very helpful advice. The book I purchased is making a lot more sense now that I've figured out what my problem was.
It's Sascha Suhr's beginner book. My problem was that in the first page or so I was informed that electricity travels opposite to how we diagram it. That just messed me up so bad for a while I couldn't read on until I dismissed it. It really is a fine book, I highly recommend it.Which book is it?
Don't let that slightly bizarre convention regarding electron flow, confusing as it may be, deter you from building moar stuff.It's Sascha Suhr's beginner book. My problem was that in the first page or so I was informed that electricity travels opposite to how we diagram it. That just messed me up so bad for a while I couldn't read on until I dismissed it. It really is a fine book, I highly recommend it.
Thanks, I am really enjoying learning what I have been so far.Don't let that slightly bizarre convention regarding electron flow, confusing as it may be, deter you from building moar stuff.
While you're at it, have a look at @BuddytheReow's tutorials right here on the forum site. Also @Chuck D. Bones and many others who post useful and informative stuff.Thanks, I am really enjoying learning what I have been so far.
There are some amp builders here, but mostly tube specialists AFAIK. They provide some creative solutions to housing such things, worth a look.I ordered a kit from Nightfire Electronics, seems like exactly what I want to build. It's a 14 watt amp with a marshall tonestack. Very clean sounding, perfect for using with my pedalboard and maybe competing with my EHX Howitzer, which doesn't have a great EQ. It's not exactly a pedal. I hope to find a project box to put it in. Anyone build anything similar?
Thanks! That's great advice! I appreciate it.There are some amp builders here, but mostly tube specialists AFAIK. They provide some creative solutions to housing such things, worth a look.
From the site: ‘The PCB is approx 5.5" wide x 2.5" deep.’ Perhaps ask what they advise or see what enclosures Tayda have that will fit.
I see from the assembled version that they apparently solder the IC directly to the board. If they don’t supply an IC socket with the kit, it’s wise to order one. It’s risky soldering that kind of component directly and using a socket means you can swap it out easily as you wish.
I built the Tayda Jfet Preamp and learned some lessons. I soldered the pot on backwards...Luckily PedalPCB had the answer on how to get it off. Then I forgot to buy a footswitch, so I wired it always on. The drilling went smooth I must say. It's not pretty work inside but the pedal works, so I am happy.
