Blue Shoe Gai Pan shorting on output jack
HELP PLEASE!!! I lose all Effect signal when I tighten the output jack. I've loosened it and no short but when I wiggle it I can tell that it is shorting on the outside of my powder coated Tayda enclosure. I placed electrical tape under the washer and that seemed to help but it will still short under certain movements. Plus it doesn't look good. I've built two of these using the same jacks and the same enclosures and the first one didn't have this issue whatsoever. Seems like I many have to encapsulate the entire jack? Any help/experience with this would be greatly appreciated. Thanks!
Reactions: fig
It sounds like the jack itself is shorting internally. Some of those are not built tightly, and the contact plates will compress.
Edit: To test this theory, de-solder the ground lead from the jack, tighten as normal, then check continuity between the lugs.
I was going to say, electrical tape almost always gets punctured by one of the component leads. More recently another member used construction paper that ended up being conductive.
They don't make dust caps for dual pots. We have these specifically for this purpose but you can insulate it with a thin strip of cardboard or plastic.
I was worried about it getting punctured and that makes sense. It was resting on the board, I can't tell if it was punctured without desoldering it but I will try a piece of plastic and reassemble
Reactions: fig
