skrattadu
I'm just built a Bluesbreaker and it's not working. Both the volume and drive pots are acting as passive volume controls, so there isn't any volume boost at all with the volume knob all the way up, it's the same volume as when it was being bypassed. I know Bluesbreakers don't give much of a volume boost anyway, but there's usually some volume increase (I've built more of them than I can count, which is why I'm so confused as to why this one won't work). Did all the normal stuff, reflowed solder joints, make sure nothing was shorting out, blah blah blah. Still, all I get is two knobs acting as volumes. Tone knob works and I can here the slight bass cut when I turn it on. I thought it might be an op-amp issue, but I had two TL072s at my disposal so I tried both of them and it didn't make a difference. Maybe the socket I used is bad. Also, I just moved and my multimeter seems to have run away so I can't measure anything until I stumble across a new one.
Any help would be greatly appreciated.
