Breadboarding Tone VEndor mk2 troubleshoot
NickC
ok everything seems to "work" except the general output volume is really too low, I know it's a mess but maybe someone can see something I don't see, thanks in advance
  • Love
Reactions: fig
Suspense is not really my jam.... ;)
The Rc3a/Rc3b network in the MK II (Rc2a/Rc2b in a FF) is a fixed voltage divider.
We all know the effects of moving a transistor stages bias point toward the power rail and to ground. Gating occurs initially and then silence happens for voltages at the power rail and glitching/velcro initially and then silence toward ground.
For the nominal 470/8.2k string with a 9 vDC source, not much of the signal is attenuate across the 470.
If you have experimented with the nominal 470 ohm RcXa value, you'll know from experience that as you increase that value, the output volume increases.
Since @NickC was essentially bypassing RcXa, the output volume would have been super low (Jumper = 0 ohm RcXa).
Is there a limit to how big the 470 resistor can be? Could I throw in, say, 1k or 4.7k?
Incorrect. Most of the signal is attenuated.
For a 8.2K / 470Ω voltage divider, the loss is 25dB. Changing the ratio of those resistors affects the volume. Changing the sum of those resistors affects the bias.
Yes, of course there is a limit to how large either resistor can be. If you go too large, then the last transistor will saturate and you get either gating or no signal. You can make the 470Ω resistor larger for more volume. Keep in mind that you are affecting both the bias & volume when you change that resistor. If you want to change only the volume and keep the bias constant, then you need to change both resistors, keeping the sum constant.
