Kroars
So, built two more Brown Betty’s one works great one works ok…. All components tested prior to install (except for IC’s).
Problem: On one of the two the trimpot doesn’t affect gain much at all. Almost like it’s always full CW even when turning. I can’t get that low gain level when the Gain knob is turned full CCW like I can with the others I’ve built. The only real difference I’ve found is that on the good pedal the pins on IC’s are standard 9v on pin 8 and close to 4.5 on others. On the bad one they’re all the same except for pin 7 on IC2 which reads 3.4v.
Also on C22 the good one goes from 4.498 to 4.489 and the bad one goes from 4.555 to 4.407 when adjusting trimpot. Seems like a bit of a difference.
IC’s were changed from good one to bad one -same issue. Also replaced trimpot -same issue.
Anyone have an idea what to check next?
Thank you!!
Thank you!!
