Rpschultz13 Well-known member Jan 15, 2024 #1 Wondering if the 2N7000 is a good alternative to the BS170 for the Acetylene Wampler 30 Something build.
KR Sound Well-known member Jan 15, 2024 #2 Check out and compare the data sheets to find out. Or just socket and rock it
finebyfine Well-known member Jan 15, 2024 #3 The pinouts are usually opposite, but you can usually get away with subbing one for the other in most pedal circuits
spi Well-known member Jan 15, 2024 #4 yes, 2n7000 and bs170 are usually interchangeable, but as finebyfine mentioned, you need to install it reversed.
H HamishR Well-known member Jan 17, 2024 #5 And the 2N7000 is a bit lower powered, which can be a good thing in some circuits.
