I don't get it.@eh là bas ma possibly found it: your "stacked" resistors - think again!
I have no idea, i am not sure i even understand the question.think: how resistores are summed up?
I don't like the way it has been done but they are in series, Are you talking about them being stacked together???think: how resistores are summed up?
bummer! to me its looks like, they are parallel. sure there is no unwanted contact?I don't like the way it has been done but they are in series, Are you talking about them being stacked together???
Take the Guess work out of the PCB & put the correct value in, We are talking 200+ Volts!!!bummer! to me its looks like, they are parallel. sure there is no unwanted contact?
Try removing your stacked resistors and just use a 220k by itself in that place. Shouldn't affect the build much.I have no idea, i am not sure i even understand the question.
I'll salvage a 330k from another build, replace the stacked resistors and report.
I recommend probing these three spots. The first two should be pretty damn loud, third should be quieter but not super quiet. If all else fails and you just need more output volume, remove R21 and/or jumper R18. That will give you a lot of volume back.I looked for instructions about "stompbox high voltage circuits troubleshooting" and such on google, but i can't easily find something useful.
Any suggestions ?
For exemple, i'd like to know wich connections in the signal path are safe to audio probe, in order to find where my volume is dropping.
I guess the pots are safe ?
Try probing before that last divider, like right at pin 3 of the Output pot. This should be as loud as the others if not louder.Thank you very much for your help !
Volume at 12'. Tone fully CW. Gain at 12'.
At R20/R13 the signal is very very loud and distorted as expected.
It's much quieter and a bit less distorted at R17/R22, but still perfectly audible, and well above bypass level.
R21/R18, i probed the middle pad of the tone pot, which is connected to these resistors. Signal disappears because it's a very faint signal. I have to set the volume fully CW and turn up the amp volume to finally hear it.
If i understood correctly, there should be the same very loud volume level at the first two points you mentioned ?
Surely there's an issue between R20/R13 and R17/R22. I'll focus on this aera and see what i can do.
If the volume was loud enough at the second location (R17/R22), i guess it wouldn't be so faint at the Tone pot...
Edit : i wonder, if it's not too much trouble, if you would be so kind to post a picture of the pcb with the numbers designations (R1, R2, etc.), please ?
I am having a hard time figuring wich 100k is R11, which 1n is C6... I know it's not a big circuit but it would be really useful, probably also for other builders in the future ?
