CA138
Hi, I am planning a project involving trying to fit the Arachnid FV-1 PCB into a Boss enclosure. Not sure whether anyone has tried this yet and I couldn't find anything similar in the search.
Basically, I had a spare PH-3 enclosure laying around and haven't built an FV-1 pedal yet - I thought they might go well together.
There appears to be enough clearance for compact jacks, 9mm pots and the board in the main compartment. I will need to work out how to make the square DC jack look pretty though...
Rate, Depth, Res controls will be CTRL 1, 2 and 3. The fourth control on the front panel will be the mini-rotary switch for the mode setting (flying leads all round of course). Volume can be an internal trimpot and for the mix control I plan to mount a 9mm pot on the side EXP hole.
Everything looks pretty straightforward, although I also had the idea of keeping the original Boss momentary switch and installing a relay bypass board in the battery compartment under the top cover. The clearance is 2x1 inches so it should fit. First time using a bypass board for me, but it looks as though this will work with the Boss switch - can anyone confirm?
Thanks for having a look - I'll post updates as I go if anyone is interested.
