giovanni
Hey guys! I haven’t worked on builds for a while and I’m slowly getting back into it. Today I boxed a Transcendence Boost in a 1590B which was exciting! However when I put the charge pump in the socket I realized I put it in backwards. So I removed it and flipped it but in the process I may have squeezed the chip too hard with needle nose pliers. I plugged the pedal in and it was quiet. Opened the back while plugged in, saw a bit of smoke come out and the chip was scolding hot
and it smelled burnt.
Could it be that I damaged it while pulling it out of the socket and then it just melted? Or maybe I had a defective chip (got it from Tayda)? I had measured each component before installing and I am pretty confident in my solder joints so I am inclined to exclude other build issues, including shorts, but before trying a new chip, is there anything I should check on the board? Anything that would have caused the chip to burn?
Almost forgot: another small issue I had was that the power plug’s center pin was bent towards the outer ring. I think it got melted a bit while soldering (I did see some solder flow towards it). I bent it back into place and it seemed fine. I assume it would either work or not (9V would short to ground). Should I replace it before trying a new chip?
Any help is appreciated!
