Caesar Chorus Troubleshooting (Rate LED Stuck on + no effect signal)
Hi everyone! I'm trying to complete a Caesar Chorus and I'm having some issues I just can't seem to figure out. I was able to get the pedal working completely fine but now suddenly, the rate LED is stuck on (so the LFO circuit is stalled) and there is no effect signal in the output, just dry. I can't seem to figure out what is suddenly causing this.
I've checked all the solder joints and they look fine. I've reheated all of the solder joints to check for bad flow and that didn't fix it. I've swapped out both IC chips, still to no avail. Kind of at a loss. Would it be that the rate pot failed?
Thanks in advanced for your help.
