Can I use an arduino mini to make a simple midi controller?
@Bricksnbeatles What type of MIDI port did you plan on using?
Either panel mount DIN or TRS— since it’s going to a device with another DIN port, it would likely be beneficial to have it be DIN on both sides of the cable so if it craps out while away from home, and music store would have a replacement cable available for sale. On the other hand, DIN is bulky, and the space savings on a board by replacing one of the DIN connectors with a right angle TRS plug would be huge, plus it’s easy enough to wire up some DIN/TRS cables, and just take spares with me wherever I bring the board.
I've had a simple little MIDI project in mind for a while, just something for my own use.
The hardware wouldn't be a whole lot different from what you need here. :unsure:
The most commonly used connectors are 1/8", 1/4", and 5-pin DIN, right?
Yup, as well as USB (usually type B), which is actually probably *the* most common type when you look beyond just guitar stuff (probably half of the keyboard midi controllers on the market these days don’t even have a DIN port, just USB-B)
What kind of stuff are you looking to use midi for in your rig?
I'm putting together a little set of helper classes to make writing code for basic pedal related activities a little quicker and easier. I have classes for switches, LEDs, relays, and IO pins.
For example, the switch class has built in debouncing and can detect short and long presses. It handles all of the underlying hardware calls (data direction register, enabling/disabling pullup resistor, etc).
Since I write AVR code so rarely I find myself always having to go back and reference my old code to refresh my memory on pin/port/bit operations. This allows me to work with a much more intuitive set of functions and put something together in just a few seconds.
Right now I'm focusing on AVR but I'll be putting together an Arduino version as well. It's really nothing you can't find elsewhere, especially in the Arduino libraries, but this puts everything I commonly use together in a nice simple little package.
For example:
Code:
// Configure Footswitch on Pin 3 (PB4)
Button footswitch(IOPin(&PORTB, PB4, &PINB, PINB4, &DDRB));
// Configure LED on Pin 2 (PB3)
LED led(IOPin(&PORTB, PB0, &PINB, PINB0, &DDRB));
// Configure Relay on Pin 7 (PB2), Default to Open, Do not invert coil polarity
Relay relay(IOPin(&PORTB, PB2, &PINB, PINB2, &DDRB), OPEN, FALSE);
while (1)
    footswitch.Update();
    if (footswitch.OnPress())
        led.Toggle();
        relay.Toggle();
Instead of:
Code:
DDRB &= ~(1 << PB4);    // INPUT - Footswitch
PORTB |= (1 << PB4);    // Enable pull-up resistor
DDRB |= (1 << PB3);    // OUTPUT - LED
DDRB |= (1 << PB2);    // OUTPUT - Relay
uint8_t lastState;
uint8_t currentState;
while (1)
    currentState = (PINB & (1 << PINB4));
    if ((!currentState) && (lastState))
        lastState = currentState;
        PORTB ^= (1 << PB3);    // Toggle LED
        PORTB ^= (1 << PB2);    // Toggle Relay
Nice.
I stumbled across this today:
SYNTHCUBE
*I've no use for it myself but it may belong in this thread
Am I understanding correctly that this allows for 80 pot/switch/cv controls digitally via midi using relays and digital pots? So you could control pretty much every knob of an entire pedalboard with midi for full-rig presets?
Information on it is sparse on synth academy's website but I think it's more or less a pcb with a modular repeating footprint for pots/toggles/inputs with a bus to a microcontroller. The way they talk about using only one wire to connect to each added element I imagine the setup is then limited by the GPIO pins on the microcontroller of choice as opposed to a matrixed input (like in a membrane keypad, etc)
Back to the original question, I just realized that there is an alternative to Arduino, the Adafruit Feather. I built a NeoTrellis a while ago and one of the applications is a midi controller. You don’t need the NeoTrellis at all, you can probably have your own buttons connected to the feather. Adafruit has been great to work with for me because their customer service is excellent. They replaced two boards for me for free because one was faulty and the other got damaged while I was desoldering the first one.
I made a midi preset switcher for my SA C4 using this guys project https://github.com/jacobroufa/midi_c4_preset - with USB host MIDI - all on an Adafruit trinket m0 - it was tiny (the board, I stuck it all in a 1590a)
Current project is using a Pi pico (programmed via Arduino IDE) to get a screen with preset names on
To get started, try this: find an example of a MIDI controller. There are many examples of MIDI controller code that can be found on the Internet. Download the sample code to your Anduino Mini. Follow the instructions in the Anduino IDE software. Automation Testing I think will help you in this regard to identify defects and problems. Then connect the MIDI controller to your computer, open your music software, and create a MIDI track.
If you're looking to dive into making MIDI controllers with Arduino, I can't recommend these courses enough! I picked them up a few years back, and the instructor not only shares all his code on GitHub but also regularly puts out awesome new content on his YouTube channel dedicated to Arduino MIDI controllers.
  • Arduino code used in making midi controllers: Github
  • YT Channel : Nerd Musician
  • Main website to check out, you can sign up for a free DIY MIDI Controller Workshop: Nerd Music
