Chuck D. Bones
Circuit Wizard
This is reportedly Bjorn Juhl's first commercial fuzz pedal. Intended to produce all of the nasty, ripping early fuzz tones, it makes raspy, velcro, gating, farting chainsaw sounds, with a little octave thrown in. I built it 95% per the drawing, altering the TREBLE control so that it actually does something and adding one resistor. There are two versions of the schematic floating around on the 'net. The difference is the inclusion of a 1K resistor in series with C7. Without it, the gain makes a huge jump when NATURE is dimed. You can see that resistor top center in the picture below, standing vertical next to the 22uF tantalum cap. I threw in one (mil-spec) carbon comp resistor just for the Hell of it. It's far enough down the signal chain that it won't be a noise contributor.
Unlike the advertising claims, the octave behavior is very fussy and nearly impossible to find on the NATURE control. I've tried different germanium transistors. The two in the photo are Russian MП38A's. I have since gone back to the 2N1308s called out on the BOM. I'm still exploring the NATURE control, which functions as a both a balance & bias control for the octave section. I don't expect the octave to ever be as smooth as a Green Ringer. The FUZZ control has a good range of gains and the pedal is capable of outputting over 1Vp-p. Not huge, but enough to make some serious boost. the VOL control is set for unity in the pic. The BOM called out a linear taper pot, but I'll probably end up changing it to audio taper.
I have not yet bonded with this pedal. Some of you may like it; I'm still on the fence.
That monster LED is actually red, the camera wants to see it as orange. Predrilled box from Tayda. I should have stripped off some of the internal powder-coat under the pots and jacks. So far, no grounding problems.
