YourGuitarist
Hello,
I am working on a pedal right now where I am troubleshooting 60 cycle hum when my hand touches the guitar strings and the other hand touches a ground surface. So in short, I think there is a ground loop forming at the input of my pedal. My input section is shown below.
I have seen variants of input where they have a capacitor in parallel with what would be R2; usually on the order of picofarads.
I have also seen variants that employ a series resistor either between C1 and the virtual ground or leading into the following op-amp stage.
I would assume the resistor is simply to limit current but am ultimately unsure. I have no idea what the capacitor does as the corner frequency I simulate is typically outside of the audio range.
So are these above measures possibly related to ground loop protection? If not, what is their purpose AND what are some common culprits of hum at a pedal input.
FTR, I am testing on an unhoused PCB with non PCB mount pots.
Any and all thoughts appreciated.
