C cniers13 Active member Jul 15, 2019 #1 Anyone know if a PNP transistor can be used if I flip the capacitor polarity? I have some OC44 transistors I want to use
Nostradoomus Well-known member Jul 15, 2019 #2 It should be okay just reverse your electrolytic caps and 9v/ground wires
C cniers13 Active member Jul 15, 2019 #4 I figured since it's a one PNP transistor it should be doable
Nostradoomus Well-known member Jul 15, 2019 #8 Oh haha I shoulda guessed really. I think you can leave the 9v/ground wires as is just flip the polarity of everything else. Also check the pin out against the original transistor (flipped of course) and you should be good to go.
Nostradoomus Well-known member Jul 15, 2019 #10 I’m not 100% sure on the flipping of the 9v/ground wires in this circuit so maybe somebody more informed can chime in I always build a negative inverter board when I use positive ground effects
C cniers13 Active member Jul 15, 2019 #11 I've done the same. Not sure what to do in this case I guess
