DAJE
...not that there's any bebop in this thread. Just trying to use an original title.
I put my back out recently, and it took a while before I was able to sit down and finish this pedal. I had everything done but the final soldering, and then I had to wait till I could sit at a desk again. Which was a tad frustrating.
I had a few MMBFJ201s that I'd soldered to adaptor boards a while back, and I tested them and found a pair that were in the right spec for this pedal. Q1 Idss = 680uA, Q2 Idss = 490uA. Tested with Peak Atlas DCA75.
Then when I tried bias them I couldn't get close till I remembered that the Sag pot needed to be ZEROED not maxxed. After that, easy peasy, 6V on each trimmer and Bob's yer uncle.
I also used an SMD 2N2222A which worked perfectly but since the PCB was made for a tin can 2222 I had to bodge up a different way of socketing the adaptor which is less secure than the neato way I did the 201s, which I copied from someone here a long time back. Since the pedal is probably for home use only I probably won't bother trying to make it tougher.
How does it sound? Good. Very good. From a dirty boost to a pretty gnarly almost-distortion, and usable for the whole range. With the Sag knob maxxed and the Drive up high, it gets quite spitty and almost-fuzzy, which is a lot of fun. A wide variety of useful sounds here, and I can recommend this one - if you're intrigued by this pedal; get it, you won't regret it.
