SOLVED Closed Circuit C106 optional or not?
micmac
Hi all,
I'm building the PedalPCB Closed Circuit at the moment. I was about to solder the caps when I realized that I'm apparently one 100nF (=0.1uF) short. The Musikding kit contains four 100nF caps. It looks to me like a fifth 100nf was not sent because the BOM contained in the PedalPCB build manual does not mention C106, although it shows up on the PCB and the schematic.
Closed Circuit build doc
I understand that in the Closed Circuit a few caps are optional. According to the build doc they're C3 and C11. But it doesn't mention C106. I cross-referenced with the Aion Gale and in there C15 (the Closed Circuit C106 equivalent) is not labelled as optional.
Aion Gale build doc
What to do? Do I leave it out or do I go buy a 100nF MKT cap (the four other 100nF are .1J63 MKT)?
Kind regards,
Seb
