Right, so this might be a common problem but it’s impossible to google…
I built Aions trace of the L4 preamp https://aionfx.com/app/files/docs/l4_bass_preamp_documentation.pdf
It has a LED indicator that the limiter circuit is limiting. It switches on a bit late (ie well into limiting) but most problematic every time it turns on it causes noise in the audio.
Before I dive in- I’ve heard this is a common issue with compressor indicator LED - either I’ve messed up something or wrong LED - but I’m looked and can’t find anything!
Yep, not the “is the pedal on LED” nor thr “optical LED - LDR compressor” just an indicator - which is why it’s such a pain to google.
Anyone point me in the right direction?
