SOLVED Corduroy possible bridge
pcb rookie
After cleaning up my board, I notice that I had a small solder splash between R6 and R17. With the magnifiers it felt close to a bridge but It was probably fin. I tried multiple things to get it off from very gentle friction with a wooded tooth pick to desolder braid and it kept visually getting worst. Now I really wished I would have left it alone. Pulled out the probe to do a continuity test between R6 & R17 and there is continuity.
Now with the questions ... is there supposed to be continuity between these two resistors or did I just create it?
Capture d’écran, le 2022-04-01 à 16.26.46.png Capture d’écran, le 2022-04-01 à 16.30.22.png
  • Corduroy Schematic .pdf
If you have a solder pen or some smd paste I. A syringe put a dot on one of the components and reflow… the solder bridge will flow and pull over to the pasted side… hot and fast!
You don’t necessarily need that, you can just add a tiny bit of solder. You can also use a solder sucker to remove excess if you feel like you added too much.
