correct jack for the headphone amplifier output?
BPFuzz
Getting a tayda order together and I realize i'm not quite sure which output jack I should be using for the headphone amplifier. Would an insulated 6.35 stereo neutrik style one work, and I just use an adapter for the size difference? Like this one
I’d assume you want a stereo jack like these. The one you have would work, but ideally you want solder lugs instead of the pcb mounted one.
Maybe even this if you only plan on the 3.5mm plugs
Thank you! Not sure how i missed the solder lug one, i'd much prefer that.
