NeedMorePedals
Hello fellow pedal builders. I am working on a Cross Contaminator. This is my 20th build, and first hiccup on a PedalPCB build. I feel pretty solid about the build. I did put monolithic caps for C4, C1, and C6. This is the first time I have used barrel transistors. Pretty sure I put them in correctly. This is my 2nd use of the 3pdt breakout board. I am getting bypass signal, and when I engage the pedal the LED comes on, but no sound. I did not individually test the components before the build, as I am still unsure how to test. I would be grateful for any advice you may have. Thank you!
