Crystals! dt-38 vs ab38t
innerlight
Hello all!
Im about to make an order for a Organ Donor (amongst others) and I cant find the recommended DT-38. However there is another 32.768 crystal available called the AB38T. Is this a suitable sub?
Thanks in advance!
hi there, As I currently have the same question as you once had here and figured I would double check to that did indeed all work out for you. I was just going though my component bins before ordering the Spacialist Reverb pcb, which calls for the AB38T and found I have some extra DT38’s from the Hydra delay.
Or use this:
Over/under clocking can have some cool effects on your…….effects
Or use this:
I bought one of these but I haven't tested it out yet, this type of stuff is a while new frontier compared with overdrive circuits!
is there a difference between the part numbers, or are they different mfgs or something like that?
