I have constructed the Electric Lover flanger pedal from PCB Mania. I have tried it with a stratocaster that contains an onboard pre amp which increases the signal and I cannot seem to rid the pedal of distortion at the end of the sweep. I have also tried the pedal with a les paul that contains hot humbuckers Classic 57 and the problem remains. Curously the pedal functions well with an acoustic guitar passive pickup which has less output signal. So my question is this: what adjustments of modifications can be made to the Electric Lover circuit design to remedy the disortion caused by hot pickups. I think I need to lessen the input signal. So do you believe it is reasonable to adjust any of R1 R2 or R3 to fix the distortion caused by hot pick ups? (P.S. The power IC in the pedal is a LM311N not a LM311P. Neither of those fix the problem.)
