Why 10µ? Have you calculated the bandwith to require 10µ? Maybe not all the audio-path caps need to be that large.
Depending on the circuit design, it may not need 10µ. The
AMZ Mosfet Booster, for instance, Jack Orman says:
The frequency response of the AMZ Mosfet Booster is flat and extends down low enough for both bass and guitar use. There is no need to mod the design to add more bass; it will not make any audible change." (
bold emphasis mine).
The Mosfet Booster's input cap is a paltry
1n (yes, 0.001µF)!
Mind that didn't stop Catalinbread from bumping the Mosfet Booster's input cap to a whopping bass-friendly 10n (as well as some other cap changes such as output going from 100n to 220n) and renaming it all as the Sogrado Poblano Picoso.
Anyway, I'm still learning the mysteries as to why a seemingly treble-some looking cap value can still let all the bass through.
For something like your build I've got some 2µ2 caps and I know you can get WIma film caps in 4µ7 from Tayda, not sure about larger Film cap sizes, but then there's always 10µF tantalums for sticking in the audio path.
